メインコンテンツにスキップ
Mac miniに搭載されたM1チップは、GPU、CPU、RAM、その他のコンポーネントを統合してパフォーマンスと効率を向上させた、アップル初のMac用SoC(System on a Chip)です。Mac miniのM1は、4つの高効率コアと4つの高性能コアを持つ8コアCPUと、8コアを持つ統合GPUを搭載しています。
Bypass Activation Lock by replacing Logic Board?
I recently made the dumb decision of buying a Mac Mini that is locked. I was not well informed when it comes to Macs and thought I could reset it easily like windows, that is not the case.
Would replacing the Logic Board of the Mac Mini A2348 bypass the Activation Lock? I keep finding contradicting answers so any help on the matter would be greatly appreciated!
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 1
コメントを追加
1 件の回答
If you can prove ownership, an Apple store should be able to help you. They require that because it's to help fight with theft.
このアンサーは役に立ちましたか?
スコア 0
4 件のコメント:
@rickwag unfortunately i bought this off someone who got it at a thrift store. Double L on my part. just wondering if changing the logic board would bypass the Activation Lock
さんによる
Hey @romy_patino , if you replace the logic board you'll have a different computer so yes you'll bypass activation lock, but the new board is completely seperate from the locked one. Basically activation lock sits on the board so that computer with activation lock is now permanently locked & as far as i am aware you can't use any hardware off that board except the micro components.
Hope this helps :). Let me know if it doesn't make sense
さんによる
@np_f1_2021
I’m not looking to reuse any components from the logic board with activation lock. I already spent $100 on the locked Mac off eBay, so at this point I’d just rather spend the $200 on a new board rather than $300 on another used Mac.
But just for clarification, if I replace the logic board I then shouldn’t have any activation lock since it’s essentially a different computer now?
Thanks for your help!
さんによる
That's right, new logic board = new computer :)
さんによる
コメントを追加
回答を追加する
Romy Patino さん、ありがとうございました!
統計データ:
過去 24時間: 2
過去 7 日: 20
過去 30 日: 100
今までの合計 395
