メインコンテンツにスキップ
The Mazda Capella was commonly known in markets outside Japan as the Mazda 626. The Mazda 626's sixth-generation was built on the GF platform and released in 1997 for the 1998 model year.
53回答 すべてを表示
car dont really want to go between 20 n 40
After I pass that it run good
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア -1
5 件のコメント
How does it run in that range?
さんによる
Will it start off slow or act like it dont want to really go the rpm get up around 4 and sometime time at just take a lil more gas to get it to go but after 40 its good
さんによる
When it is not in gear how does the engine sounds when you slowly push on the accelerator? Any misfires, shaking, anything different in the way your engine sounds or behaves?
さんによる
there no different it sound good
さんによる
Did your service engine light come on? Does it just hesitate or does it sputter and buck when you are in that speed range? Right now I am leaning toward either a vacuum leak or transmission issues. I assume it is an automatic....
さんによる
コメントを追加
1 件の回答
ベストアンサー
When was the last time the fuel filter was replaced? A partially restricted fuel filter can supply enough fuel for the engine to run OK at idle, but not run properly under load.
BILL
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
ken tilmon さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 0
今までの合計 404
