Right joycon random inputs on his own
My right joycon at random times start pressing random inputs. Sometimes it is ok for 2 hours but then starts again
Hi!
Okay, so every button is pressing them selves? If this is the case, you might want to open the controller and check what’s going on!
First I would clean everything with isopropyl alchol and see if that works.
Otherwise, it is a motherboard issue here. Replacing this one can solve this kind of issue. But please clean it first and see how it goes!
このアンサーは役に立ちましたか?
I cleaned everything but now only the joystick works
Hmm, how are the SL and SR buttons? Also the ZR button, does this one work?
So, the A/B/Y/X buttons aren't working, but is the + and home button working?
Which buttons are failing at the moment? You can test any button on the Switch. Please follow this guide: https://en-americas-support.nintendo.com...
Please let us know which ones are working. Thanks!
過去 24時間: 0
過去 7 日: 0
過去 30 日: 3
今までの合計 52
