Won’t turn on
Novice DIY here. Have a Bravos XL that seemed to have stopped mid wash. Read up on some things. Power supply is blinking green. Control panel has no power. Tried cleaning where I could see corrosion. Order a panel ?? Fuse ?
Hi Vince,
I haven't had a chance to look into this in any depth for you, but I did locate the tech sheet for your washer. This has service information including wiring diagrams and troubleshooting steps that will be a must see to try and diagnose the issue. Here's a link to the PDF file.
I've also gone ahead and uploaded it to the device page so it will be available as long as iFixit is around.
Techsheet W10607408 Revf - iFixit
As I mentioned, the tech sheet has you covered. Here's the part you're interested in.
=== Problem ===
Won’t Power Up
• No operation
• No keypad response
• No LEDs or displayPossible Cause
No power to washer.
Checks & Tests
Check power at outlet, check circuit breakers, fuses, or junction box connections.
Possible Cause
Connection problem between AC plug and main control.
Checks & Tests
Check the AC power cord for continuity
Possible Cause
Connections between main control and UI.
Checks & Tests
Check connections and continuity between main control and UI.
Possible Cause
User Interface problem.
Checks & Tests
See TEST #4: Keys and Encoders, page 17
Possible Cause
Main Control problem.
Checks & Tests
See TEST #1: Main Control (ACU), page 14.
このアンサーは役に立ちましたか?
Appreciate it. I’ll try to make heads or tails of it. I believe my problem is off J18 going to the user interface board to the controls. Not sure if I got a voltmeter. Stay tuned
Same issue. Here is mine. I watched this video. https://youtu.be/IpLF007BXmw?si=HrbwqCuu...
Of my four rectangular parts on the circuit board only the top one is dark and slightly corroded so I’m trying to clean it. I was having the same issue of it stopping mid cycle.
過去 24時間: 0
過去 7 日: 2
過去 30 日: 9
今までの合計 113
