メインコンテンツにスキップ
Repair guides and disassembly information for the 16-inch MacBook Pro released in November of 2023, featuring M3 Pro and M3 Max SoCs.
Replace top clamshell, keep existing display?
My Macbook late 2023 16'' MRW33LL/A top half was recently damaged, its all bent but the display works fine. Could I replace the clamshell/mounting hardware and maintain the display? Or is the clamshell/display considered a single piece?
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 0
1件のコメント
How did this happen? It looks like the display was forced back somehow.
さんによる
コメントを追加
1 件の回答
ベストアンサー
Ouch! The Display assembly is a unitized part. Apple does not offer any of the discrete components. Apple has cracked down on factories funneling parts out the back door bypassing the Apple tax.
Sadly, that only leaves you with replacing the whole assembly. Now the not so fun part, Apple introduced hardware serialization a few years ago which limits what you can replace using removed parts (another Apple Tax!) so you need to get the part directly from Apple or one of their parts distributors if you want to fix your system on your own. Here's the site Self Repair and here's the manual MacBook Pro (16-inch, Nov 2023) and here's the parts breakdown page Orderable Parts, jump down to item 36.
Once you replace the display you will need to calibrate it (updating the systems parts serial number) and align the zone backlight with the display.
このアンサーは役に立ちましたか?
スコア 1
2 件のコメント:
Exactly what I needed to know, unfortunate but glad I don’t have to guess about it. Thank you!
さんによる
Self-repair has gotten a lot more straight forward since the last time I needed to fix a mac. Only about $820 for everything including the hinge covers and tool rental. good stuff.
さんによる
コメントを追加
回答を追加する
Jk. さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 9
今までの合計 87
