Why it vibrates when I tap it?
When I tap my iphone with my finger near to the vibrator (left from the home bottom) I feal a little vibration on my hand without hearing some noise. Is this normal or I have trouble?
この質問は役に立ちましたか?
この質問は役に立ちましたか?
Well the vibration motor sits under the lower left side of the motherboard on the back....So it would be the lower right side on the front of the phone. If there is a screw out of place or the contacts are not straight and aligned with the contacts on the bottom of the motherboard it may cause that. If its been apart, try pulling the motherboard back out and make sure the vibration motor is straight and the contacts align properly with the two pads on the bottom of the motherboard.
Hope this helps!
このアンサーは役に立ちましたか?
Mine does the same thing.
I fixed by not tapping it anymore.
このアンサーは役に立ちましたか?
+great answer ;-)
過去 24時間: 0
過去 7 日: 0
過去 30 日: 0
今までの合計 1,421
2 件のコメント
Well - not sure if it's normal but mine does the same thing.
Kmarkg さんによる
Yes, Mine does the same when I Tap it at lower side, near the Home Button...
any Fixes...?
Muhammad Zubair Saeed さんによる
