メインコンテンツにスキップ
Repair guides and specifications of the HP Envy 17t, released in 2017. The HP Envy 17t has a 17" display, 16GB of RAM, and an Intel Core i7 processor.
What repair is needed since: Boot device not found
When I start the computer whether hard reset and so on, I get a black screen with white writing stating the following:
“ Boot device not found
Please install an operating system to your hard drive
Hard disk (3F0)
F2 System Diagonostics
For more information: please visit www.hp.com/to/techcenter “
However, I do not find anything at the tech center and I do not hear if the hard drive spins up, maybe it is quiet??? I am not sure if the error on the black screen is just looking for the Microsoft operating system to be downloaded??? This computer was working then it stopped giving this error above. I am not the only one who uses this computer so I am not sure what another might have done. What should I do? Thank you Vincent. Seaset1@yahoo.com
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
1 件の回答
最も参考になった回答
Hi @vincent20934
Get into the BIOS menus and check if the HDD is being shown as detected by the BIOS > System Configuration > OS boot manager.
Here's how to do this in your laptop.
  • Turn on or restart the computer and quickly press f10 – or – turn on or restart the computer, quickly press esc, and then press f10 when the Start menu is displayed.
If there's no HDD shown then it has failed and needs to be replaced.
What is the model number of the laptop as shown on the product information label on the bottom of the laptop? Knowing this will help to find the correct service manual for your laptop.
If there is a HDD being shown, the problem may be due to a faulty/corrupt boot partition on the HDD.
To fix this create a Windows Recovery USB disc. This can be done from any known working Win10 (or Win 11) PC. All you need is an 8GB (or 32GB for Win11) USB flashdrive and 1-2 hours of time.
In the host PC go to Control Panel > Recovery > Create a recovery disc and follow the prompts.
Once you have the recovery USB, insert it into the laptop and then turn on the laptop and press the F9 key a few times (or get into BIOS) and change the boot order to USB as the 1st boot option, the laptop should then boot from the USB drive into the Windows Recovery Environment menus.
When in WRE go to Troubleshooting > Advanced > Startup repair and follow the prompts.
このアンサーは役に立ちましたか?
スコア 1
コメントを追加
回答を追加する
Vincent さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 2
過去 30 日: 8
今までの合計 72
