メインコンテンツにスキップ
Repair guides and support for gas, electric, and human powered machines used to cut grass, whether self-propelled or “walk-behind.”
Why is my mower idle low and barely cuts without dieing
Why is my mower have a low idle rpm and never comes up. Also dies if cutting any grass taller than 1 inch
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
1 件の回答
最も参考になった回答
Hi Randy,
While you may get some generic answers by just telling us you're working on a lawn mower, chances are you'll get a much more specific answer if we know the manufacturer and model number of your particular lawn mower. I suggest editing your post to add that information to get some better responses.
As an example, if I knew the model number I wouldn't have to ask if this is a gas or electric mower. Assuming it's gas, have you removed the air filter and cleaned it or at least tried to run it without? Does it have a fresh tank of gas? Have you checked anything in the carburetor, such as the needle valve or float bowl? How about the spark plug; did you try cleaning it and checking the gap?
What have you done to try and troubleshoot the problem so far?
このアンサーは役に立ちましたか?
スコア 1
コメントを追加
回答を追加する
Randy DeWoody さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 3
今までの合計 50
