メインコンテンツにスキップ
より早い処理スピードを可能にしたiPhone 3Gのアップグレード版です。このデバイスの修理は3Gと似ており、標準のドライバーと開口ツールが必要です。モデル番号 A1303 / 16 もしくは 32 GBの容量 / ブラックもしくはプラスチックの背面ケース
1502回答 すべてを表示
iPhone constantly searching for signal and end up with No Signal
I have opened my iPhone 3GS to replace battery. I am not sure what was the damage I have done to my phone. After reassembly, it's searching for signal and finally says no signal. I gave the phone to local repair shop, they have tried changing the doc connector from a working phone but still no luck. I have made the small copper tooth near connector 7 touching the silver frame. Still no luck. I suspect connector 7 on the mother board is damaged. I have attached my mother board pics here. http://www.flickr.com/photos/79479917@N0...
Has anyone faced this issue and replacing connector 7 male connector in the board will solve the issue?
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア -1
コメントを追加
3件の回答
ベストアンサー
looks more like the screw hole is damaged? might be the corner of the motherboard has been flexed and cracked the internal wiring from no7 to antenna reception or there is not good contact with the little gold pin on the top of the dock connector. this a 3G but the idea is similar.. http://www.mauron.net/iphonerepair/
I'd try Gido's advice about testing the blue coil first though.
このアンサーは役に立ちましたか?
スコア 2
コメントを追加
最も参考になった回答
Your connector looks somewhat damaged indeed. If it does not fit well it could cause a bad connection which can result in the problem you are facing.
I have replaced several of these connectors on the motherboard successfully to repair this kind of problem.
You may also want to check if the blue coil near the connector is still OK. These also tend to break. You can measure this with a multimeter. Should be between 0-10 ohms or so.
このアンサーは役に立ちましたか?
スコア 2
2 件のコメント:
Many thanks for helping. I will arrange a multimeter to check the blue coil. Meanwhile, can you please tell me how much it would cost to replace connector 7 in the board?
さんによる
Connector is quite cheap, a few dollars or so, if you are able to replace it yourself.
Normal price for a repair by a technician is somewhere around 50 euros or so (at least that is what I normally charge for this kind of repair).
さんによる
コメントを追加
you can get theiphone signal inductor coils here
3G
3GS
4G
4GS
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
sayhiworld さん、ありがとうございました!
統計データ:
過去 24時間: 1
過去 7 日: 2
過去 30 日: 2
今までの合計 2,473
