GE GSE25GYPFCFS Dispenser light keeps turning on and off
The dispenser light on the door of my GE fridge keeps turning on and off; I've tried resetting the breaker, but keeps doing it. Any ideas as to what is causing it?
Hi @phillipkoz40610,
If it is only the light that comes on and no water being dispensed it may be a problem on the display control board.
If water also comes out then it may be an intermittent dispenser switch contact
Can't find a copy of the mini manual online (GE p/n 31-1000523) but here's an article that states where it may be located in the refrigerator and if it's not there then how it can be obtained from GE.
The manual hopefully will show the wiring for the light so that its operate circuit can be seen.
If the problem is on the board itself, then the board may have to be replaced as usually there are no schematics available for GE boards, or none that I've ever found anyway.
このアンサーは役に立ちましたか?
過去 24時間: 0
過去 7 日: 0
過去 30 日: 3
今までの合計 66
