Door is not closing tight
Door not closing tight so green light is blinking
Is the freezer level in all directions i.e. front to back and side to side?
Place a sheet of paper between the door and the door jamb and with the door closed normally, i.e. no pressure by you on it to keep it closed, try pulling the paper out. It will come out with a bit of an effort but not easily and it shouldn't fall out by itself. Try this at various places around the door, top, bottom and both sides.
If it does come out too easily, check the seals are not bent or broken and that the door is straight and parallel to the cabinet just in case it's a problem with the hinge.
If the seal needs replacing, search online for 5304534456 to find suppliers that suit you best.
Here's parts list an image of the wiring diagram for the freezer that may also help, if it isn't one of the problems above.
(click on image)
このアンサーは役に立ちましたか?
過去 24時間: 0
過去 7 日: 0
過去 30 日: 5
今までの合計 49
