メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
The Toyota Camry is an automobile sold internationally by the Japanese manufacturer Toyota since 1982, spanning multiple generations. Originally compact in size (narrow-body), later Camry models have grown to fit the mid-size classification (wide-body)—although the two sizes co-existed in the 1990s.
2006 Camry 2.4L - Vehicle Speed Sensor
So my camry has been running fine until last week I began to get hard gear shifts, then the ABS, check engine, and brake lights came on. The speedo also stopped working. The code indicated a VSS issue. At first I tried replacing it with a cheap sensor. All the warning lights went out and the speedo worked when I first started the engine, but the second time I started it all the warning lights were back and the speedo stopped working. I replaced the sensor again using a Dorman VSS 917-603 ($151.00). The same thing happened; it fixed all of the issues and I drove it for about a mile. This morning when I started it all the warnings were back with no speedo again!
I have no idea what to try now :-(
Does anyone have any thoughts?
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
1 件の回答
still having issue?
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
Mark Sproul さん、ありがとうございました!
統計データ:
過去 24時間: 3
過去 7 日: 3
過去 30 日: 6
今までの合計 57
