メインコンテンツにスキップ
1.83、2.0、2.1、 2.16、2.2、または2.4 GHzのいずれかのCore 2 Duoプロセッサーを搭載したModel A1181
1203回答 すべてを表示
SSD or HDD in PATA bay?
MacBook Core2Duo A1181
I've bougth a SSD and DVD bay to upgrade my MacBook. The bay is PATA to SATA, because old superdrives are PATA on these MacBooks.
I plan on using the SSD for system files and apps, and the current HDD for my media. I use my computer for music creation, so I need quite fast access to my HDD.
Where should I put my new SSD ?
- In place of the current HDD : my system will boot very fast, and so will my apps. But what about my HDD behind the PATA interface ? Will it be quick enough ?
- In the bay ? Will I see any improvement using a SSD behind a PATA interface ?
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア -1
コメントを追加
1 件の回答
ベストアンサー
There should be no noticeable lag or difference if you have a high quality conversion. The bus speed at either port should be sufficient for your use. Only you can determine if there's an "improvement". Some people get very wrapped up in computer speed minutiae - for most uses/applications a human will not recognize any difference.
If this Answer is helpful please remember to return and mark it Accepted.
このアンサーは役に立ちましたか?
スコア 2
1件のコメント:
Thanks for the reply.
I did receive the package in the mean time, so I installed the SSD on the SATA port and my old HDD in the caddy.
Everything is rolling, now, I'm launching OS X in ~20 seconds and my apps start in a snap. My audio files are very quickly accessible. I'd recommend this kind of update to anyone with a similar computer.
さんによる
コメントを追加
回答を追加する
Cedric Delalande さん、ありがとうございました!
統計データ:
過去 24時間: 1
過去 7 日: 3
過去 30 日: 3
今までの合計 948
