メインコンテンツにスキップ
Microsoft Corporationが設計したXbox One Sは、2016年8月に発売されました。Xbox One Sは、Xbox Oneを再設計した製品です。
What is this part called?(white plastic)
What's that white plastic part called?
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
1 件の回答
ベストアンサー
Hi!
Disc intake/loading tabs. Or eject assist tabs.
I do not know how to call it otherwise. Are you planning to replace them? Those parts are difficult to find.
このアンサーは役に立ちましたか?
スコア 2
6 件のコメント:
Yes, I tried googling it and it just pulled up CD drives. I've been trying to find this for like a month! Lol One day my cd got stuck and I tried the paperclip manual eject and nothing. Opened it up and that white plastic part had broken and it was off the rail. Thank you!
さんによる
Ahh, yeah then it won't eject indeed! My pleasure! If you can't find the parts, you could replace the drive. This is expensive, but then it should work. OR you can buy a broken drive and take the parts out there, this will be less expensive.
さんによる
Still couldn't find the part by itself so yeah, gotta go disc drive replacement which I hear you gotta solder a few things because the motherboard is linked with the drive. *sigh*
さんによる
:(. It's hard to find the specifc parts (if possible at all). Yes. You do need to transfer the original drive it's PCB to the replacement drive to let it read games...
さんによる
I'm not too knowledgeable on this but could you take your hard drive from an old xbox one s and put it in a new xbox one s and you wont have to install or download anything or is that a no go?
さんによる
1以上のコメントを表示
コメントを追加
回答を追加する
John さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 3
今までの合計 107
