メインコンテンツにスキップ
2017年6月8日に発売。A1418 / EMC 3069 / 2017 / 3.0 GHz quad-core i5, 3.4 GHz quad-core i5 or 3.6 GHz quad-core i7 Processor.
Installing OS on a Fusion Drive (my iMac is 2019)
Im not very experienced on iMacs all my experience is on PC, anyway, I tried to reinstall my OS via the internet on my (Fusion Drive) as I suspected I had malware, anyway when I finished formatting the SSD and the HDD (in Mac Journaled) it only gave me the option to install the new OS on the SSD which is too small and not on the HDD - 1TB which is where I wanted to install. Why isn’t the HDD available as an available volume? Can anyone help?
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
1 件の回答
Ah, you fell into the trap! The SSD mustn't be formatted, you need to leave it Raw so the installer preps it as the Cache drive for the HDD.
Most of the time I just pull the Blade SSD's out and install a 1 or 2 TB version to maximize the system's performance. Setting up the Blade SSD as the boot drive and hosting the Apps leaving a good part of the drive empty so Virtual RAM, OS caching and paging (if running BootCamp) have plenty of room and the current project before moving it over to the HDD. Leaving the HDD as the primary storage of my media and work files.
At the time Apple went down this path SSD's were quite expensive! So to get a bit more performance out of the disk drive which was also still not as good as some of the newer platter drives, Apple added a smaller SSD as a cache to the HDD. Today the needed drive is not that bad cost wise OWC Aura Pro X2 SSD and if you're upto it here's the guide iMac Intel 21.5" Retina 4K Display (2017)ブレードSSDの交換
Replace or upgrade the PCIe solid-state drive in a variety of Macs.の画像
製品
OWC Aura Pro X2 SSD
$199.99
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
Jimmy H. さん、ありがとうございました!
統計データ:
過去 24時間: 2
過去 7 日: 5
過去 30 日: 9
今までの合計 72
