メインコンテンツにスキップ
1.83、2.0、2.1、 2.16、2.2、または2.4 GHzのいずれかのCore 2 Duoプロセッサーを搭載したModel A1181
1203回答 すべてを表示
Antenna cable is broken. Do I have to replace it?
While replacing the inverter on Macbook A1181 Early 2009, I noticed the gray antenna cable is sliced and the black one is nicked. Do I have to replace them or can I remove some insulation, twist and put some electrical tape on it? A friend just suggested soldering the two pieces together. Thoughts?
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア -1
コメントを追加
1 件の回答
ベストアンサー
Well, replacing them will guarantee a fix and guarantee that no further problems arise.
Fixing the wires yourself will cause any variety of problems if you don't do it exactly right. And thus end up costing you a lot more money to replace the hardware they have damaged.
Personally, I'd replace them.
If you fix the wires incorrectly it will cause problems and I just wouldn't feel comfortable with my abilities to not screw some minor thing up.
However, if you feel absolutely confident with your soldering and repair abilities you can certainly fix them yourself.
But I wouldn't recommend attempting it unless you have a lot of direct experience repairing and working on computers, have screwed up a couple so you know what not to do, and know precisely what you're doing.
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
BridgetSchober さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 0
今までの合計 526
