メインコンテンツにスキップ
The Kenmore 110 Series is an easy to use home Washing machine created by Kenmore.
Cord is getting hot
Why is Cord getting hot, smells like electric burning ?
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
1件のコメント:
Hi @dcdobbs,
What is the model number of the washer?
Don't use the washer until the problem has been fixed
さんによる
コメントを追加
1 件の回答
@dcdobbs the power cord heats up because of an excessive current running through it. You want to consider having an electrician check your outlet to make sure it can handle the amperage your washer needs. Also, you do need to check the washer to see why it draws to many amps. At minimum you will need a multimeter and preferably a clamp ammeter. You can get those relatively inexpensive at major hardware store or somewhere online.
このアンサーは役に立ちましたか?
スコア 0
1件のコメント:
When it comes to AC you do not mess with dubious meters - NO. You want a good one like a Klein. Fluke is obviously the preference but most people can't throw $230 at a Fluke 115. Ideally the minimum should be $60-100 to get one that is safe for such use.
I tend to like the Klein meters for high voltage work on a budget, but my preference is Fluke every single time.
さんによる
コメントを追加
回答を追加する
DCDobbs さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 3
今までの合計 53
