My 1999 rx300 takes alot to start and loses power
Very hard to get started and loses acceleration fairly often while driving . It's intermittent but then after feathering the peddling gas it comes back. What is the cause of this?
Have you scanned the car for any trouble codes? When I had a similar issue on my '99 VW New Beetle, it turned out to be a failing MAF, or Mass Air Flow meter. An OBD-II scan showed a code for that issue and replacing it fixed the problem.
このアンサーは役に立ちましたか?
Yes codes say bank one too lean . And something about bank 2 ac sensor. Idk what they are . Have new plugs and wires , new mass air flow sensor, new 02 sensor . Still having issues not sure what else to do from here.
@davidreza24695 Can you give us the specific codes you retrieved? That may help pin down what's going on.
過去 24時間: 0
過去 7 日: 0
過去 30 日: 7
今までの合計 85
