Why does the camera run down in ten minutes?
I charge the camera - with several new batteries - and it runs down within ten minutes. How can I fix the charging mechanism?
この質問は役に立ちましたか?
この質問は役に立ちましたか?
Because the battery in your device has aged, if possible, you can replace the camera or buy a battery to replace it
このアンサーは役に立ちましたか?
I have tried four new batteries, and two new battery chargers - and also charging it from the computer.
@jmartz42667 Fast power consumption solution: Turn off WIFI: WIFI function can be turned off when not in use to reduce power consumption. Adjust backlight and warm light settings: Reducing backlight and warm light can lower power consumption. Waiting for the download and indexing process to complete: After the device completes the download and indexing process, power consumption will return to normal
過去 24時間: 0
過去 7 日: 1
過去 30 日: 8
今までの合計 90
1件のコメント
jmartz さんによる
