メインコンテンツにスキップ
Xiaomi Redmi Note 11 4G Released 2021, December 01 181g, 8.9mm thickness Android 11, MIUI 12.5 128GB storage, microSDXC
How to fix when your phone cant touch
How to fix a phone when you cant touch
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 1
コメントを追加
2件の回答
最も参考になった回答
@kyelerw I think you missed the point of the post; my reading says the digitizer has failed, not the display.
@princemharb6163 Most Android phones will automatically recognize a wired mouse when it's plugged into the USB port, and you can use the mouse in lieu of a working touch screen. I've done that on my Google Pixel when it would not respond to the touch screen; that allowed me to reboot the phone; in my case that was all it took, but if your digitizer has failed completely you'll need to replace the screen to fix it.
I just used an old school Logitech wired USB mouse with a cheap USB-A to UBS-C adapter. Once plugged in, a mouse cursor will appear on the screen and using the mouse you can click anywhere you would normally touch.
このアンサーは役に立ちましたか?
スコア 1
コメントを追加
You can use software like AirDroid to remotely control your device. If the touchscreen still works, but you can't see it, you can use volume shortcuts to activate feedback. You can also plug get an HDMI converter and plug your device into it and connect it to a monitor to see what is supposed to appear on your screen through the monitor.
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
Prince mhar blantucas さん、ありがとうございました!
統計データ:
過去 24時間: 2
過去 7 日: 12
過去 30 日: 39
今までの合計 276
