メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
Lenovo ThinkPad L470は、LenovoのLシリーズに属する14インチのビジネス向けノートパソコンです。標準的な構成には、発売当時のIntel Coreプロセッサ、エンタープライズ向けのセキュリティオプション(TPMや指紋リーダーなど)、ドッキングサポート、取り外し可能なバッテリーなどが含まれます。実際のバッテリー駆動時間は、特定の構成によって異なります。
Battery not charging forward
My battery doesn't charge forward when plugged in
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 1
2 件のコメント
Some keys in my keyboard are not walking
さんによる
@ayabongamabona could be an issue on the circuit board for the keyboard. Remember that each key is actually a microswitch etc. that closes a circuit that will then be interpreted by the IC. A failed IC (on the motherboard) could be the issue but luckily most commonly it is the keyboard that has failed. Here is the ThinkPad L470 Hardware Maintenance Manual Page 76 will tell you how to change your keyboard. Replacement keyboards are readily available.
さんによる
コメントを追加
1 件の回答
最も参考になった回答
@yoogee not sure what you mean by "doesn't charge forward" but I assume you are saying it does not charge. first off, we will need to know how old this battery is. A depleted battery will not accept a charge, not matter how hard we try. If this is a known good battery then thee are a few other issues you need to check.
First you want to check your power supply. Make sure it has the proper voltages. Check to make sure that connectors are not bend etc. Check the DC-in jack of your laptop. Make sure there is no corrosion, debris etc. that prevents it from working. Clean it of any debris etc. Use a few puffs of air to clean it out. If none of this works, get an ammeter and see if your laptop draws any amperage from the charger. After that, you need to check and see if your motherboard even gets power. For that of course, you need to open it up. Post Some good pictures of what you see. That way we can see what you see. iFixitでの質問に画像を追加する方法
Use the ThinkPad L470 Hardware Maintenance Manual to work on your Lenovo.
While you work on your Thinkpad, take lots of pictures. Once you are done with it, take those pictures and create a guide for iFixit. That will help the next person that has a device with the same issues as you do. It's easy and fun to create these guides. https://ifixit.com/Guide/new The iFixit community will appreciate this.
Repair is War on Entropy!
Let us know how things are working out with each check/test.
このアンサーは役に立ちましたか?
スコア 1
コメントを追加
回答を追加する
Yoo Gee さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 7
過去 30 日: 17
今までの合計 375
