メインコンテンツにスキップ
Nintendo DS Liteは、ニンテンドーDSの後継モデルとして2006年に発売されました。このデバイスの開口作業は簡単で、修理もシンプルです。
turn on and then immediately off
My daughter dropped her ds on the floor and now it will turn on and then immediately off. I tried charging the battery and even replacing it with another good battery from another DS we have, but still the same problem. The right most light turns green when powered on for about 1 second but then shuts off
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 24
6 件のコメント
trun on problams
さんによる
plz talk to me
さんによる
Ha (that happiness to me to)I don't know how to fix it
さんによる
How to fix a DS lite that turns on and instantly off
さんによる
I have this issue after I rehoused the system. the botton screen turns on, and the blue light comes on, but then shuts off after a second.
さんによる
1以上のコメントを表示
コメントを追加
8件の回答
最も参考になった回答
Unfortunately it could be a variety of problems. Fortunately they all have workable solutions.
Perhaps the easiest problem to fix would be if, when it was dropped, one of the cables became loose or disconnected. In that case all it would take to fix it would be to open the DS up and ensure all the cables are properly seated.
A more difficult one to address is it is possible that when it was dropped a component was knocked off the main board. And it is quite common for an inductor to get knocked loose in a drop, located near the power switch. But it is an easy solder if you happen to work with electronics.
If you want to further diagnose the issue I'd recommend using the following guides to disassemble the device and check for possible damage:
Nintendo DS Lite
Though there is another apparent option which centers around possible hinge damage. Does it appear that there was any damage to the hinge in the fall?
If so you may just need to replace the casing and one of the screens to rectify the issue. In which case the above guides would also be useful.
Also, if it turns out you need replacement parts, this is a good spot to start looking.
このアンサーは役に立ちましたか?
スコア 13
6 件のコメント:
+ damage to the hinge damages the cable connecting the top LCD and can give the turn on turn off issue.
さんによる
That´s the answer I was looking for. tnks
さんによる
it work on my ds
さんによる
turn on problams
さんによる
Lol, it's been a long time since literally "jiggling the cables" was a solution. Disconnect, and reconnect, the 3 ribbon cables, works like a charm.
さんによる
1以上のコメントを表示
コメントを追加
one of the connectors is not connected anymore
このアンサーは役に立ちましたか?
スコア 1
コメントを追加
hold the power switch on a maximum 1 hour and keep the ds game inserted.
if your daughter wants swap the ds game your daughter will need a gba game
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
maybe it was just from the fall
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
Hi, if you’ve got no flash screen, consider to try my fix here.
The DS won't turn on. Green light flashes for a second.
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
The problem might be in the battery compartment
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
i will try shaking mine and see if that works, since i might just get a new one, if we can't fix it
このアンサーは役に立ちましたか?
スコア 0
1件のコメント:
i did not work :'(
さんによる
コメントを追加
My aunt’s DS lite’s power switch is broken. I would slide it to the on side but then it just moves to the off side. Is that supposed to happen?
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
khan786 さん、ありがとうございました!
統計データ:
過去 24時間: 17
過去 7 日: 95
過去 30 日: 434
今までの合計 94,072
