メインコンテンツにスキップ
2023年6月に発売されたNokia G42 5G Androidスマートフォンの修理・分解情報です。モデル番号はTA-1573、TA-1581またはTA-1591です。
Poor reception on Nokia G42
I bought my parents a G42 each at the same time. One of them broke the screen, which I replaced. That same phone is now on the same network as the other and we've noticed that it gets a much worse mobile connection than the other phone (that never had any bits replaced).
For example, the repaired phone only gets Edge but the "untouched" one gets 5G in the same location.
The repaired phone has only recently been changed into the same network as the "untouched" one, so it might well have had a signal issue for a while, possibly ever since I repaired it.
Can anyone advise what the best resolution is? For example, I wonder if the antenna is on the back panel, and perhaps the contacts between this and the main board need cleaning?
Thanks for any help and advice!
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
1 件の回答
The black and white cables that start from above, flank the battery and reach the bottom are responsible.
I also had problems with the connection and I solved it by DISASSEMBLING everything (except the battery) and REASSEMBLING, paying particular attention to:
  • the cleanliness of the parts
  • the perfect wiring
  • A STRONG TIGHTENING OF THE SCREWS
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
robincm さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 10
今までの合計 101
