メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
GSM 3Gセルラーネットワーク(AT&T)に対応し、16、32、または64GBのストレージ容量を持つ第2世代Apple iPadの修理ガイド、分解、トラブルシューティング情報。デュアルコアA5プロセッサを搭載。2011年3月発売。モデル番号A1396で識別されます。修理には熱の使用と慎重なこじ開け作業が必要です。
Any way to repair scratches in the screen?
I have a single scratch on my screen about 1.5" long. I'm not looking for a polish to "remove" the scratch as that's simply not possible. However I've seen product in the past that was nothing more than a liquid that you would put on scratches (for example, eye glasses) that would fill the scratch and make it so it's doesn't refract light anymore thus...bye bye scratch, for the most part.
It's been a long time since I've used any such product or have worn eye glasses for that matter. However, has anyone used those product on something like the iPad?
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 11
3 件のコメント
Awesome, thanks Gary! Especially for the actual product recommendations.
さんによる
Hey no worries, it's what we're all here for, just let me know if you need any further help.
さんによる
The right side of my iPad glass,has chipped glass 1 deep & 1 shallow can I repair with some kind of glass filler? Thnx
さんによる
コメントを追加
6件の回答
最も参考になった回答
1 Purchase display polish. You can purchase this product from several online retailers and from many brick-and-mortar cellular phone stores. iDrops, Displex Display Polish and AstroShine Clean Kit are three types of display polishes you can use to remove scratches from your iPad.
2 Open the display polish and squeeze a small amount of the polish onto your iPad. Consult the instructions that came with your display polish to determine the recommended amount of product to use for a single application. Typically, you will use a few drops.
3 Polish the scratched area for two to three minutes. Apply heavy pressure using the clean, soft cloth.
4 Repeat as necessary to remove deep scratches.
NOTE
If you find the scratch is too deep to remove with a liquid fill solution, you may have to replace it.
You can find those directions at this link :)
iPad 2 GSMのLCDの交換
For future reference I would suggest buying a screen protrector to better help your iPad from becoming scratched again. If you need further assistance please just ask.
このアンサーは役に立ちましたか?
スコア 6
コメントを追加
what is this prouduct called
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
I suggest caution: all these products contain abrasives that remove the special finish that helps prevent finger prints. You may only do more damage to the display surface.
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
It really depends on the type of material the touch screen is composed of (Glass, Acrylic, Gorilla Glass). I would suggest using a buffing agent that is specific to your type of device screen as to not damage it any further. These guys have it broken down by screen type so you might look into what they have or something similar from another manufacturer.
TDI-LLC Technology - Glass, Acrylic, Gorilla Glass Compounds
Hope this helps.
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
c est vrai attention aux produits mais on ne fait pas de miracles !! autant essayer avant de changer l écran ?
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
F u c k off
このアンサーは役に立ちましたか?
スコア 0
1件のコメント:
why would you need to make a comment like that?
さんによる
コメントを追加
回答を追加する
Justin さん、ありがとうございました!
統計データ:
過去 24時間: 2
過去 7 日: 8
過去 30 日: 45
今までの合計 49,184
