Sony Walkman NWZ-E436F went thru washer can't open it to dry
I removed the two screws on the back but still can't open it up- Help!
この質問は役に立ちましたか?
この質問は役に立ちましたか?
Judy, get the service manual from here . You will see that it has clips the holds the both halves together You can try to open it with the iPod opening tools. Once open, use this guide to clean your Walkman. Hope this helps, good luck.
このアンサーは役に立ちましたか?
Mine is a japanese item but i don't know japanese at all.please help me use it.thank you very much !
このアンサーは役に立ちましたか?
Have you tried the service manual from the above link? what have you tried so far?
I'm reading it
過去 24時間: 0
過去 7 日: 5
過去 30 日: 8
今までの合計 2,193
