メインコンテンツにスキップ
iPadアクセサリ用の修理ガイド
90回答 すべてを表示
締切られた回答
Charge 2 USB devices with 1 charger!
I have a 10 Watt USB charger that came with my iPad and I wish to charge both an iPad and an iPod touch at the same time! I tried a USB hub but that didn't work! I also dont want to buy anything extra! Any ideas?
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
2件の回答
最も参考になった回答
What you want is the XtremeMac Incharge Duo 2.1 amp Dual Charging Dock which allows you to charge your Ipad and iPhone touch at the same time.
このアンサーは役に立ちましたか?
スコア 2
2 件のコメント:
Thats helpful but i need a solution that doesn't require me to spend any cash!
さんによる
@ Jeremy Scalpello, probably not, unless you rewire your USB hub. Take a look at this site http://zedomax.com/blog/2008/07/28/diy-h... There is much more to charging an iDevice than a USB port. You also want to check on pinours.ru and study the wiring for the dock connector. Unless you have all the parts in your possession, you will have to spend some $$. Either charge the devices separately, or go the way Gary suggested. Good Luck
さんによる
コメントを追加
Even if you split the output to two devices sending 5W to each device, the iPad won't charge. It needs all 10 watts. It might RUN on 5 watts, but not charge. The iPod however will charge double-time with 10 watts, so charge that first.
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 0
今までの合計 673
