メインコンテンツにスキップ
Released in June 2022, model number T779W, codename "Challenger_TMO", has an integrated stylus.
Why is my TCL showing the headphones symbol
My phone shows the headphones symbol and won't play any sound through my phone speaker
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
1 件の回答
Hi @reixy4k
Can you hear any sounds if you plug a set of headphones into the phone?
If you can then try plugging/unplugging the headset of few times to see if this resolves the problem. It may be a sticking contact inside the headphone jack in the phone that was causing the icon to appear when nothing was plugged in.
If you can't hear any sounds in the headset when it is plugged in and trying to clear the problem as suggested above doesn't work then most likely the headphone jack in the phone needs to be replaced.
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
reixy4k さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 3
今までの合計 63
