メインコンテンツにスキップ
Microsoft Corporationが設計したXbox One Sは、2016年8月に発売されました。Xbox One Sは、Xbox Oneを再設計した製品です。
Xbox One S turns on then turns off
Hello, Everyone. I have an Xbox One S that, when powered on, plays the startup chime, the light shines white, and then plays the shut-down chime and turns back off a few seconds later. The console's fan does not spin during this. I have attempted a PSU replacement, but with no results. I took the board out and discovered some corrosion in a corner of the board, but I cleaned it off with some 91% Isopropyl Alcohol. All help would be appreciated.
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
3 件のコメント
Update: I have just replaced the fan which didn’t make any difference. There is still no fan spin and the console still turns off with a chime about 10 seconds after being turned on.
さんによる
Which corner of the board had the corrosion?
さんによる
@flannelist It was on the corner closest to the CPU.
さんによる
コメントを追加
1 件の回答
最も参考になった回答
Hi!
Unfortunately this issue is common. The issue is on the motherboard somewhere. Did you checked the capacitors? Do they look fine? If yes, it still could be a capacitor or the MOSFET which is failing. This requires soldering and soldering skills.
Check for a short on the 12V rail and the power MOSFETs to be sure.
Please let us know how it goes!
このアンサーは役に立ちましたか?
スコア 1
1件のコメント:
Sure then, ill have to go and purchase a multimeter and check that.
さんによる
コメントを追加
回答を追加する
TechVid さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 3
過去 30 日: 9
今までの合計 112
