メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
Hot water kettle with digital temperature control.
Thermostat decreases by a few degrees every few seconds
A while back my kettle was scaled over pretty badly and as a result ended up boiling over several times. I set it to dry it with some desiccant packs, but since then, every time I turn it on, the thermostat readout starts ticking down from whatever my desired temperature by a few degrees every few seconds.
For example, if I turn the kettle on with cold water and set the temperature to 100 degrees Celsius, after about a minute, The set temperature readout (not the reported thermometer reading) willbe down to 90 degrees Celsius. So if I want boiling water, I have to keep turning the knob to the right.
What could be the problem here and how might I go about fixing it?
Update (03/26/25)
I've de-scaled the kettle several times since this problem started, and it makes no difference.
The problem seems to be with either the control knob or the thermostat
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
1 件の回答
Sounds like the control panel got wet so it thinks you are pressing the lower temp button. The minerals within the water can leave a deposit or cause corrosion which electrically shorts out the wiring or interferes with the switches action. You might be able to clean the spillage using distilled water or 90% isopropyl alcohol. If you see green or rust you might try white vinegar or rust remover. Make sure the area if fully cleaned afterwards using cotton swabs.
このアンサーは役に立ちましたか?
スコア 0
4 件のコメント:
as it turns out, descaling has no effect on the thermostat knob. it appears to either be the themostat circuitry, the control knob, or something else
さんによる
@bennypower22259 - Didn’t think descaling would have altered things. But if the solution spilled into the electronics then that could be an issue. You’ll need to open the bottom to gain access to the board and then carefully remove it.
さんによる
I opened her up with some prying picks, a triangle bit, and the steel prying bar from my toolkit (careful, there are some snaps around the sides which you need to pry apart gently).
I didn't notice any obvious corrosion, but i'm inexperienced.
さんによる
New info: if I carefully turn the knob so that it almost-but-not-quite clicks, ie so that the clicky rotary encoder is in tension and doesn't fall over into the next click, THEN the thermostat setting stays constant.
Does this indicate that I could either repair or replace just the encoder?
さんによる
コメントを追加
回答を追加する
Benny Powers さん、ありがとうございました!
統計データ:
過去 24時間: 2
過去 7 日: 6
過去 30 日: 18
今までの合計 349
