メインコンテンツにスキップ
A range of laptops designed for medium-to-high performance gaming and content creation.
Why cant I reset my laptop
i am not able to reset my laptop.
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
4 件のコメント:
Yoosaf, can you clarify what you mean by "reset"? Are you saying Ctrl-Alt-Del doesn't work, or the reset button won't restart the computer, or you can't reformat the hard drive, or what? The word reset can have several meanings and we can't guess which one you mean, so please elaborate on what you are trying to do so we can help you figure out how to do it.
さんによる
When i am trying to rest i am getting message no changes were made. There was a problem with resetting your pc. Also sometimes my laptop wont start when it start i get a message from the startup screen that "Alert! Memory error occured"
さんによる
@yoosafmihadad what is the exact model for your laptop and what operating system are you using?
さんによる
I am using dell g15 and windows 11
さんによる
コメントを追加
1 件の回答
First, that RAM error means one of the modules is generally bad on these - it doesn't surprise me since the OEM Dell RAM on the consumer side is not as good as on the business PCs and even aftermarket RAM. It isn't terrible - it's just not as long-lasting. The OEM RAM on these Dells is problematic ENOUGH you ought to replace both sticks with good RAM from Corsair or retail-packed Crucial RAM (Micron-branded modules are the "OEM" version) when it fails - skip the OEM stuff Dell sells; it's not much better. That said, if you want to try swapping the modules around and running a memory test, use Memtest 86+ to see if it has any errors after running for at least 4-5 hours MINIMUM. These OEM modules from Dell don't always immediately fail out, but they do begin to fail things like memory testing with a few hours of stress. There's a reason when I buy gaming PCs from Dell I buy them with 16GB and buy aftermarket RAM kits to install 32GB; it's cheaper and I've had better luck with aftermarket RAM then the OEM Dell modules.
The "there was a problem resetting your PC" error is a MAJOR red flag - it generally means the recovery files got corrupted at some point, or the machine had a malware infection that corrupted them by design to prevent easy rollbacks. The machine is not in a stable condition. Now you can run SFC /SCANNOW in admin mode, reboot the PC, and undo the corruption. The downside is this generally only works under these conditions:
  • It's not a virus
  • The damage done is easily recoverable (rarely is)
Sadly, your best bet there is to backup the PC, get a copy of your drivers on a USB drive, and reinstall Windows with an image from the Media Creation tool:
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
Yoosaf Mihadad さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 6
今までの合計 104
