メインコンテンツにスキップ
Gaming laptop released by Dell as part of their G series of laptops in 2019.
5回答 すべてを表示
I NEED TO ADD 16Gb OF RAM MEMORY
What is the original 16gb memory for this laptop and how do I insert it? And where? I have never done this by miself and need some help... It already has 16Gb and I need some upgrade. And a question: does it have 1 or 2 slots? Thx to you all!
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
1 件の回答
最も参考になった回答
Hi @sergiozilb25651
Here's the service manual for the laptop.
Go to p.27 to view the procedure to remove/replace the memory.
The specifications show that the laptop supports up to a maximum of 32GB of DDR4 2666MHz sodimm memory in 2 slots i.e. 2 x 16GB modules.
If you want to match the 16GB memory that is already installed (is it 1 x 16GB or 2 x 8GB?) so that they're identical e.g. latency, frequency etc, you would need to check what information is shown on the module itself.
If you have to replace both modules (if 2 x 8GB is installed currently) then ensure that you get a "matched pair" to avoid any operating problems
このアンサーは役に立ちましたか?
スコア 2
コメントを追加
回答を追加する
SERGIO ZILBERSTEIN さん、ありがとうございました!
統計データ:
過去 24時間: 3
過去 7 日: 7
過去 30 日: 30
今までの合計 30
