メインコンテンツにスキップ
iPhoneの第4代目で、修理はそのままパーツを直接交換するだけです。しかし、正面ガラスとLCDはセットで交換する必要があります。容量はGSM / 8,、16m32 GB / モデル番号 A1332 /本体カラーは黒と白色
20回答 すべてを表示
Ways to put iPhone back together FASTER?
I run a small iPhone repair business. It takes me 10-15 minutes to take the iPhone apart. but 35-45 MINUTES TO PUT IT BACK TOGETHER! The screws are so hard to work with!
What can I do to improve the speed of putting it back together?
I'll take any advice!
Thank you
Rob
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 2
2 件のコメント
I use double sided tape..stick the screws head down on a diagram of where they go, makes pick up easy & if you use left hand pick up/hold phone on table, right hand magnetised screw driver. I don't think I'm quick but it saves the frustration of having all the screws lift up with screwdriver. I'm happy being slower and more careful than being fast and making a mistake that'll cost me money to fix. (says she who has spent the morning trying to stick an LCD flap back on an ipod 5th video because she tried to rush!!)
さんによる
how to hack telesom company
さんによる
コメントを追加
6件の回答
最も参考になった回答
In general, magnetic screw mats really help with keeping screws organized.
If you're looking for an iPhone-specific solution, you might like the magnetic screw mats that iFixit sells for the CDMA (Verizon/Sprint) iPhone 4, the GSM (ATT) iPhone 4, the iPhone 3G/3GS, and the iPhone 4S.
For a more general solution, there's this magnetic organizer mat. It even has little trays for non-magnetic parts :)
Edit: I've used magnetic mats in my repairs, and have never had a problem with them. To be on the safe side, just keep the LCD and battery off of the mats, and you should be fine. The magnetic field from these type of mats isn't strong enough to damage things from a distance. :)
Organize and magnetically secure your screws and small parts on a dry erase surface. Make notes with included pen.の画像
製品
Magnetic Project Mat
$19.95
このアンサーは役に立ちましたか?
スコア 4
1件のコメント:
i use them all the time, great tool!
さんによる
コメントを追加
Usually I don't remove the last six screws that hold the screen. I just loosen up them a bit.
You might have to shake a bit when replacing the new screen but this saves the frustration of putting back those screws with these tiny rings.
このアンサーは役に立ちましたか?
スコア 2
コメントを追加
Make sure you're using the correct Philips screw driver. I can't tell you how many times I've had customers bring me back iPhones with stripped screws. If your driver is not snug or spinning even a little while fastening or loosening... It is the wrong driver.
Also please note that the tools you get free from most lcd replacement buys are not the right driver. They are smaller and will strip screws.
このアンサーは役に立ちましたか?
スコア 1
コメントを追加
practice makes perfect, use to take me an hour to do the full repair of touchscreen replacement or anything. I learned that other technicians in the area do it in 20 minutes. This was starting to become a turning point for customers. Each repair now takes me a total 18minutes for the iPhone full repair. I use to follow the tape ways, etc but that was really slowing down the process.
My solution to you, when you take a screw out place it in front of you where u took it out, and make an invisible phone. So when u put them back you just put them back where they came from based on the invisible phone. Its also mostly you have to memorize each screw, its not as hard as you think. iPhone is one of the quickest and easiest repairs out there.
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
Do it more, ALOT, embrace failure, and practice practice practice (BE THE IPHONE)
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
If we're talking about an iPhone 4 CDMA, I just timed myself and did it in 9 minutes and 14 seonds, I seen this video on youtube of a guy doing it in 7 minutes and 11 seconds. The only thing that is bringing my time to be so terrible is picking up the screws, I have to individually touch every single one, any ideas for picking them up better? I am just using an anti-static mat, nothing magnetic. Any ideas will be greatly appreciated! #GuinessHereWeCome
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
J Sull さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 0
今までの合計 9,832
