メインコンテンツにスキップ
Repair, disassembly, and troubleshooting information for the Samsung Galaxy A15 smartphone, released in December 2023.
20回答 すべてを表示
My phone is heated during insert two sim card
My phone is hot during insert two sim card
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
1 件の回答
最も参考になった回答
Hi @demelashali
If you don't need to be connected to the internet all the time, try enabling the data saver setting and check if this helps to stop the phone from overheating.
Here's a video that shows how to do this.
Enabling this setting will prevent apps from using the internet in the background without you knowing about it, causing the phone to work harder (and heat up) unnecssarily.
When you want to go on the internet or even to send/receive mms messages (texts with pictures, videos etc - ordinary sms messages are unaffected) just disable the data saver setting whilst you're online.
Also if it isn't necessary check that the WiFi and BT are also turned off, because if they're on, they are constantly searching for networks and devices to connect and pair to, causing the phone to heat up
このアンサーは役に立ちましたか?
スコア 1
コメントを追加
回答を追加する
Demelash Ali さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 1
過去 30 日: 10
今までの合計 10
