メインコンテンツにスキップ
The Kenmore Elite HE3 is 7.2 cu. ft. capacity electric dryer by Kenmore.
318回答 すべてを表示
checked everything and still no power
have checked power to everything and still no power, its not the door switch because the inside light is not even on, and the themal switch is good, and i have power to the dryer everywhere it just will not do anything, please help
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 1
コメントを追加
3件の回答
最も参考になった回答
Try unplugging it for 5 minutes to reset it, then plug it back in. Remember an electric dryer runs off of two 110 lines in the USA. So throw both breakers at the breaker box to be sure it's getting full power.
このアンサーは役に立ちましたか?
スコア 3
コメントを追加
Your drum light is not a good indication that the door switch is working. Actually, if your door switch is not working, your drum light will not receive any power. Check the wiring diagram on your original question.
このアンサーは役に立ちましたか?
スコア 2
1件のコメント:
Update? My dryer isn’t getting power either
さんによる
コメントを追加
Tried everything you recommended and still nothing. Surly someone has solved this problem. Who has the answer. Percy 601-638-1646
Update
checked power to dryer, thermal fuse, door switch all ok. this dryer was working fine one day and nothing the next. No lights or anything just dead.
このアンサーは役に立ちましたか?
スコア 0
3 件のコメント:
What symptoms does your dryer have? What have you tied so far? What have you checked?
さんによる
If you already checked all the parts and found them to be in working condition, I recommend a new control panel assembly.
さんによる
How do you test a control panel board, My unit has exact same problem and board loos to the eye as good as new. gordo89120@gmail.com Control board is expensive $180 on Amazon, though it is an easy repair. But costly if that is not the problem.
さんによる
コメントを追加
回答を追加する
kory hentges さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 4
過去 30 日: 11
今までの合計 2,030
