メインコンテンツにスキップ
The Samsung galaxy A04s is an affordable smartphone with a large display and decent battery life. It offers basic features and functionality for everyday use.
20回答 すべてを表示
Why is my screen not responding to touch?
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
1 件の回答
Could be a software problem or it could be a hardware problem.
If it's software then restarting the phone and/or booting into safe mode should get it working again. If it does work in safe mode but not on a regular boot, then you've got an app interfering with the touch screen and you'll need to go through and delete them until you find the offending one. If your phone requires you to tap a button on the screen to restart it (like mine does), you can plug a wired mouse into your USB port and use that to mouse to the button and click on it.
If no software solutions work, then chances are your digitizer has failed. On all modern phones the touch screen is bonded to the display so the entire display has to be replaced in order to fix it. iFixit doesn't have a guide, but I located one on a French site that has exactly what you need.
Galaxy A04s Screen Block Repair - Free Guide - SOSav.fr
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
s.k.mell7826 さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 9
過去 30 日: 21
今までの合計 21
