Switch asks to detach when playing games
When playing games Switch requests joy controllers to be detached to carry on playing
Hi!
Thanks for the video!! It looks like either the Switch it’s rail failed, or the joycon it’s rail.
Did you tested the Joycons on another Switch? This would be the ultimate test. If they work on another one, it’s your Switch it’s rails. If not, it’s the joycon..
You can also test other joycons on your Switch and see how that goes!
このアンサーは役に立ちましたか?
Thanks I don’t have access to another Switch unfortunately. Are these issues repairable?
Yes! Both of them can be repaired :)! Usually it's the Switch it's rail that failed. But we can't be sure. Is there a way to test another Joycon on your Switch? Anyway, if you need to replace the rail on the Switch. You can find the part and guide here: Nintendo Switch 右側ジョイコン センサーレールの交換
Do you repair them as well or are these relatively easy to repair?
Yes, I repair many of them! It’s an easy repair! You do not need to remove many components to get there, so that is always a plus :)!
過去 24時間: 1
過去 7 日: 5
過去 30 日: 17
今までの合計 179
5 件のコメント
Hi!
Can you share some pictures with us or a video? Thanks!
koppie007 さんによる
Please see attached video
JimH830572 さんによる
Please see attached video[video|6626]
JimH830572 さんによる
Hi! Still can’t see it :(. Can you upload it somewhere? Sorry!!
koppie007 さんによる
[video|6626]
JimH830572 さんによる
