メインコンテンツにスキップ
Nintendo DSiは任天堂 DSラインの第3番目となるモデルです。2008年後期に日本で発売されました。
DSi blue light flashes and nothing else happens
I have a dsi that the blue light will flash when I press the power button. The top and bottom screen kinda turn a different shade of black for a split second, but nothing else happens. I have tried:
new battery
new daughter board
replaced both screens
cleaned all cable connectors
checked for water damage
soft reset/ hard reset in case of missed update
Replaced the wifi board
I even removed the motherboard and placed it into a known working DSi, but it still had the same issue. The mother DSi is my brother's and has been very well kept. It has no cosmetic or physical damage at all. What would I be looking at as possible reasons it doesn't work?
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
1 件の回答
最も参考になった回答
Hi Owen!
It sounds like you’ve tried everything! So it must be motherboard related. The easiest thing to do, is to replace the motherboard.
You can buy them here:
https://a.aliexpress.com/_EyQsNCY
They are not that expensive anymore, so it’s worth the try!
このアンサーは役に立ちましたか?
スコア 1
2 件のコメント:
I was hoping to fix the motherboard. It has downloaded the games we played. Before I replace the board, I will try to replace the digitizer ribbon cable connector. I heard that may be the issue.
さんによる
Ahh, I see. Yes, you can try that first. Please also double check all the ribbon cables to see if they are connected properly.
さんによる
コメントを追加
回答を追加する
Owen Lee Snook さん、ありがとうございました!
統計データ:
過去 24時間: 1
過去 7 日: 5
過去 30 日: 15
今までの合計 34
