メインコンテンツにスキップ
Similar to the Dell OptiPlex 7010 in specs.
Why my pc shuts off halfway in loading a system?
Hello.
I have a Dell Optiplex 9010 DT (Desktop Tower, it's just low profile version) and it tries to boot, but after a minute or so it restarts. Is this a problem with the PSU? Or what is failing? And, if it's the PSU, do I need to buy the OG part or are there replacements?
Power supply is a 250w (?) one, CPU is i5 3rd gen (i5-3470) and I got more RAM (two DIMMs instead of one, both 4gb and none og). Not only that, but also a WiFi card.
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 1
5 件のコメント
Hi @marciko
Can you get into BIOS and leave it there for a while, without it restarting?
Can to start the OS in safe mode without it restarting?
さんによる
I didn't try that yet. I'll try it later. I feel like the whole PSU disables tho...
さんによる
@marciko
When trying to locate problems it is easier to find out what works or doesn't work and then progress from there.
For example if you can get into BIOS and it stays on then generally the hardware is OK.
If it turns off in BIOS then you check is it turning off due to a heat problem for instance e.g. fan not working or dried thermal paste on CPU so PC is shut down etc
If safe mode stays on then it's looking like a driver problem in Windows
If it stays on in BIOS but turns off in safe mode is it a HDD problem etc
At least in narrows down where to start looking rather than assuming where the problem is.
さんによる
Fixed: Dell is bad platform. I got a new PSU that I run externally. I'll make a new cover so that the PSU can be mounted. The Dell's proprietary design is bad. They only produce(d) it and only in 250 watt variant.
さんによる
Correction: many more produce TFX (the format that is in most office PCs except ATX and maybe SFX)
さんによる
コメントを追加
2件の回答
ベストアンサー
So, in short it doesn't output enough wattage when cold or left for a year or two. What I recommend: if it's the full tower, replace the PSU to higher wattage (should just be ATX), meanwhile other ones are usable when you aren't pulling too much current.
Edit: I tracked down what form factor of PSU I have. It's TFX, which is very office computer (HP, Dell and even some servers)
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
Several factors can cause your computer to shut down automatically. It could be a motherboard, loose connection, overheating, or software issue. If you think it is a hardware problem, you should check the power supply first. Ensure it's plugged in properly and the cord isn't frayed or damaged.
このアンサーは役に立ちましたか?
スコア 0
2 件のコメント:
I had another PSU (ATX, not the proprietary of DT I have) and changing it fixes all issues. It also is the same with 7010 DT. I already replaced the PSU once. It's just Dell being Dell.
さんによる
Correction: the DT and SFF PSUs are TFX, less standard but still common
さんによる
コメントを追加
回答を追加する
Marciko さん、ありがとうございました!
統計データ:
過去 24時間: 1
過去 7 日: 4
過去 30 日: 11
今までの合計 136
