メインコンテンツにスキップ
Released in 2004, the Logitech MX510 is an optical gaming mouse. It has a USB cable for connecting to your computer and uses an MX optical sensor on the bottom for tracking movement.
2回答 すべてを表示
Logitech MX510 mouse right button works sporadically
The right button on my Logitech MX510 mouse has stopped working reliably. Sometimes it works with normal pressure, sometimes only with a lot of pressure, and sometimes not at all. Occasionally it will "ghost click" with no pressure at all. Any ideas on how to fix it?
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 3
コメントを追加
5件の回答
ベストアンサー
You might try a brief spray of contact cleaner on the switch. I would first test where it wouldn't show to make sure the cleaner won't damage the finish. Ralph
このアンサーは役に立ちましたか?
スコア 2
コメントを追加
最も参考になった回答
You might need to replace the micro switch. The micro switch can be remplaced by Omron D2F-T.
このアンサーは役に立ちましたか?
スコア 4
2 件のコメント:
I replaced mine with Omron D2F-T and got a worse clicking experience since the Omron D2F-T is much harder to press than the original micro switch. The original micro switch is called D2FC-F-7N, I'd recommend getting that, I'm changing it also to mine.
さんによる
I replaced the right switch with one of the extra switches on the left side. There are 5 identical switches and the left ones I never use.
さんによる
コメントを追加
How old is it?
Try spraying some compressed air between the buttons.
このアンサーは役に立ちましたか?
スコア 1
コメントを追加
Probably a dodgy connection in there somewhere. Take it apart and look around...
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
Hi, I had the same problem with another Logitech mouse. I took apart and I realised, that the button died. I took apart a 10 years old mouse. It contained exactly the same button. I used the dissipative solder sucker and disoldered the buttons out ( I recommand to use midle or right button, because they are not use so often, so you can expect they are in better condition). Be careful! If you don't have any experience with soldering/desoldering, practise with any unuseful parts. If is your new button out, try to measure if is working properly. If so, you can solder it in. Your mouse should be ready to work.
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
Brian Anderson さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 3
過去 30 日: 7
今までの合計 10,380
