No signs of life
My buddy will give me this computer if I can fix it. He raged and slammed the keyboard and the area to the right of the trackpad. When I plug it in it doesn’t show any charging lights and the power button doesn’t do anything. There are no signs of damage like the motherboard cracking or the battery puffing up. I already checked for any loose or unplugged connections and I power cycled the battery by unplugging it and plugging it back in. If anyone has any ideas I’d really appreciate some help.
Have your tried removing the battery and SSD and then plug it in to see if it comes on to a boot screen?
The impact is most likely affected the underside of the motherboard so there might be a fault on the other side. Are you able to remove it and check for damage on that side?
honakrisi さんによる
no boot screen. I was an idiot and didn’t plug the charger into the wall but now that it has power It has symptoms that could possibly be diagnosed. When I press the power button the keyboard lights up and the fans spool up for about 3 seconds before abruptly stopping. Nothing shows up on the screen. I will check underneath the board
Colin Best さんによる
