メインコンテンツにスキップ
Lenovo Thinkpad P51 repairs, replacements, and teardowns announced in February 2017.
Random shutdowns occuring under high load with new ifixit battery
I recently replaced the original battery, which was at around 45% health with a new ifixit battery. The ifixit battery has excellent battery life, however, I've discovered an issue whereby when under a high load when not plugged in, the laptop will randomly shutdown. It does not shutdown gracefully, simply switching to a black screen immediately. I've tested this on a number of relatively resource intensive games, with the same results. This does not occur with the old battery. Lenovo Vantage reports the battery as being in good condition so I'm at a loss as to what is causing this.
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
1 件の回答
ベストアンサー
Hi @simonrooney
Try uninstalling the Microsoft ACPI Compliant Control Method battery drivers in Device Manager > Battery, and then when they have been uninstalled, close all open windows and restart the laptop in the normal manner.
During the following startup, Windows will reinstall the drivers. Check if the problem still occurs.
このアンサーは役に立ちましたか?
スコア 2
1件のコメント:
Hi @jayeff, that's solved the issue. Thank you very much :)
さんによる
コメントを追加
回答を追加する
C.B Gang さん、ありがとうございました!
統計データ:
過去 24時間: 1
過去 7 日: 2
過去 30 日: 6
今までの合計 109
