メインコンテンツにスキップ
Power on problem and charging
My Samsung Ao2 had screen problem so I sent it for repair and after the repair, when you try to turn it on, the screen lights will just flash then go off.Also, if you plug it on charge, the charging sign will show up and go of.it with continue like that till the next day
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
1件のコメント:
Hi @saibuhannan
Have you contacted the repair service about the problem?
They shouldn't have returned the phone to you in that condition. It should have been tested by them, after the repair, to make sure everything worked OK before they gave it back to you.
さんによる
コメントを追加
1 件の回答
The user is having problems with their Samsung Galaxy A02 after it was repaired. The screen lights will flash and then go off, and the charging sign will show up and then go off as well.
There are a few things that the user can try to fix the problem:
  • Force restart the phone: This is done by pressing and holding the power button and the volume down button at the same time for a few seconds.
  • Check the charging cable and port: Make sure that the charging cable is properly plugged into the phone and that the port is free of debris.
  • Try a different charger: If the phone is not charging with the current charger, try using a different one.
  • Boot into safe mode: This will start the phone up with only the system software running. If the phone works in safe mode, then the problem is likely caused by a third-party app. The user can then uninstall the apps that they recently installed one by one until the problem is fixed.
If none of these solutions work, then the user will need to take their phone back to the repair shop or to Samsung for further diagnosis.
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
Saibu Hannan さん、ありがとうございました!
統計データ:
過去 24時間: 1
過去 7 日: 5
過去 30 日: 25
今までの合計 54
