メインコンテンツにスキップ
Repair information and disassembly guides for smart home security devices including locks, alarms, and sensors.
Kwikset Premis Replacing the screen/keypad
Does anyone have any experience replacing just the keypad/screen of a Kwikset smart lock? I see parts for it being sold but cannot find any instructions or videos on how to replace the screen.
https://www.ebay.com/itm/156517927825?mk...
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 1
コメントを追加
1 件の回答
ベストアンサー
I actually had this same question and purchased that keypad replacement from eBay. The process to remove and replace the part was pretty straightforward. Remove the lock from the door, and remove the 6 screws that hold the metal plate on the back of the keypad. Once you remove the plate, you will need to remove 1 ground screw, and the keypad will come out. Replacement is the opposite, just need to make sure the cable stays in the channel so it will ensure a proper fit.
このアンサーは役に立ちましたか?
スコア 1
2 件のコメント:
Yep that’s exactly what I did. Worked like a charm. I wish I would have taken pics step by step but if anyone has questions feel free to reach out.
さんによる
How can i find the replacement can you put finding thanks
さんによる
コメントを追加
回答を追加する
viclopez1112@me.com さん、ありがとうございました!
統計データ:
過去 24時間: 2
過去 7 日: 10
過去 30 日: 43
今までの合計 467
