メインコンテンツにスキップ
Stuck on descaling mode
My machine is stuck on descaling mode and I can’t exit. Help me fix it please.
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
2件の回答
@shamsalameen Try a factory reset.
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
As you may know, the second phase of the descaling process is the phase with rinsing with pure water.
The machine exits the descaling process only if sufficient amount of water flowed through the machine during that second phase.
If it was too little amount of water during that second phase, the machine remains in descaling mode.
Solution: Try descaling, and for the rinsing phase completely fill the water tank up to the very top with water.
I have read, sometimes people even had to refill the water tank during the actual rinsing process (i.e. when water was still flowing).
Then the machine will exit the descaling mode.
このアンサーは役に立ちましたか?
スコア 0
1件のコメント:
Interestingly, it was mostly the "Touch" models that I heard this issue about.
さんによる
コメントを追加
回答を追加する
Shams Alameen さん、ありがとうございました!
統計データ:
過去 24時間: 1
過去 7 日: 6
過去 30 日: 27
今までの合計 64
