メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
2015年3月にアップデートされたAppleのMacBook Pro 13" Retina Display Early 2015 はモデル番号はA1502、第5世代のIntel Core i5と i7プロセッサーが特長でForce Touchトラックパッドを備えています。
Keyboard and trackpad are unresponsive.
Tried :
trackpad
trackpad cable
resetting SMC
resetting PRAM.
Is it possible to be a logic board issue?
Theres no visible damage on the logic board.
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
2 件のコメント
By "Tried :" you mean you have replaced the parts or something else? Can you be more specific?
さんによる
@livfe - I have replaced the trackpad / cable
さんによる
コメントを追加
1 件の回答
最も参考になった回答
Are you able to get an external USB keyboard and mouse to work? If you can see if running diagnostics offers an error. Using the keyboard restart and press and hold the D key to enter into the onboard diagnostics. Let us know the error.
Reference: Mac startup key combinations
このアンサーは役に立ちましたか?
スコア 1
6 件のコメント:
@danj - Only error was one telling me to test the charger, Nothing regarding the keyboard.
I wonder if it's firmware related.
さんによる
@beanman56 - Settings maybe, firmware not likely. Most likely the keyboard or its cable.
Lets dig deeper… open About This Mac and click on System Report. Now slide down to USB under hardware, click on it which will open the two viewer windows. Click on Hub which will list out the devices in the lower window is the Keyboard & Trackpad listed? Likewise the external USB ports will show the external keyboard and mouse/trackpad. Can you see them?
さんによる
@danj - It doesn't show up, The external keyboard and mouse do.
さんによる
@beanman56 - OK, that’s aiming is back to the hardware. Let’s do this after powering the system down, carefully disconnect the keyboard cable referencing Steps 27 & 28 in this guide MacBook Pro 13インチ Retina Display Early 2015 ロジックボードの交換. Now reconnect the battery and turn the system on, look at the Hub settings again any luck? The trackpad should still now be visible
さんによる
@danj - So... Nothing appeared. I'm assuming it's the keyboard cable.
But is there anything else I can try before I buy a new top case?
さんによる
1以上のコメントを表示
コメントを追加
回答を追加する
Ben Capehart さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 1
過去 30 日: 17
今までの合計 152
