メインコンテンツにスキップ
Repair guides and troubleshooting for HP Pavilion dv7 laptops, manufactured by Hewlett-Packard starting in 2008, and featuring a 17.3" diagonal display.
137回答 すべてを表示
Can I replace the ATI Radeon HD 6370 card on my laptop?
I have an HP pavilion dv7 with a Radeon HD 6370 video card that has been intermittently crashing, but now the problem is worsening. I have scanned the various troubleshooting recommendations and have determined, to the best of my ability, that:
1. The card crashes when the computer is cold or hot, but more frequently when the computer has been on for a few hours.
2. Windows researched the cause of a crash a while back and informed me that the error was caused by the ATI card.
3. I am using the most up-to-date driver.
4. My spouse is an electrical/computer engineer and is going to replace the card if I can purchase another one. To that end, I have these questions:
+ Is the card a standalone or is it soldered onto the motherboard?
+ Is there another card that might be more reliable that I can purchase instead?
+ Where can I purchase a replacement card?
Thank you.
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 3
コメントを追加
2件の回答
ベストアンサー
Not being exactly sure which model of the dv7 you have, I go with a pretty generic answer. Most graphics card are embedded into the motherboard on laptops, making swapping the graphics card extremely difficult or not physically possible. Now, some laptops were fitted with a technology called "MXM" which was developed by nvidia and it allowed the end-user to remove a add-on graphics adapter and replace it with a compatible upgrade. Hope this helps, good luck.
このアンサーは役に立ちましたか?
スコア 1
コメントを追加
If you asked for discrete graphics when you bought it, it should have a separate graphics card, but i'm not sure about this.
The best way to find out is to get your screwdriver out and see for yourself.
Here's the repair manual: http://h10032.www1.hp.com/ctg/Manual/c01...
Good luck!
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
Heather さん、ありがとうございました!
統計データ:
過去 24時間: 2
過去 7 日: 7
過去 30 日: 11
今までの合計 9,443
