メインコンテンツにスキップ
9月22日に発売されたアップルの "小型 "フラッグシップスマートフォン2023の修理、分解、トラブルシューティング情報。6.1インチProMotion OLEDディスプレイ、トリプルレンズ背面カメラシステム、5Gを搭載。iPhone 14 Proの後継モデル。
Camera won’t calibrate
Camera won’t calibrate. Keeps saying no objects found, restarts camera & goes back to finish repair.
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 1
2 件のコメント:
You probably have a ripped camera flex or some dirt between the connectors. You could try to disconnect the cameras again, clean the connectors with some IPA and reconnect. Be sure to check the flex cables for rips or hard fold lines.
さんによる
Camera was cleaned & checked, not sure I want to go to the trouble of opening it again. Camera works fine just won’t calibrate
さんによる
コメントを追加
1 件の回答
Did you use an original part from Apple? As long as you see an preview, when you do the calibration, make sure there are objects within your surrounding. This can be items on your desk or furniture in the room. This proces can be a bit long but just keep turning the phone until is says finished. Hope this helps.
このアンサーは役に立ちましたか?
スコア 0
2 件のコメント:
The camera was purchased on ifixit, when I do the calibration it says Apple part . I’ve made sure there’s objects in view, it doesn’t recognize them & they are large objects. I get the same message over & over. Then it restarts & the same message appears that I need to restart & finish repair . I’ve tried this many times & it just won’t calibrate.
さんによる
I took my camera to a repair business and now mine is getting the same message. The camera works great just can’t seem to locate item to calibrate on.
さんによる
コメントを追加
回答を追加する
Hairstylistroxx さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 10
過去 30 日: 53
今までの合計 523
