My 2015 BMW F700 GS won’t start
Hi,
My 2015 F700 GS won’t start, the battery is at optimum health and has no issues.
When I start the ignition the lights and all things on dashboard do come alive like it would normally, no sign of oil required or low gas.
The fuel pump also makes the sound of one bleep indicating it is working.
What could possibly be the issue?
I am in cold weather, minus 5 but the motorcycle was not starting since November 4 which was not cold at all.
Please help.
Thank you.
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
5 件のコメント:
@sanketmore does the engine crank over (is the starter working) or does it not do anything?
さんによる
Yes, the starter works. But engine doesn’t fire up.
さんによる
@sanketmore one more check. Do you have spark on the spark plug? I usually just pull the plug connector and use a different sparkplug and hold it close to the engine block. Then try to start your bike. See if you have spark.
さんによる
@oldturkey03 I need to check that, where can I locate the spark plug?
さんによる
@sanketmore check something like this video at about 5:20 to learn about the spark plugs
さんによる
コメントを追加
