Where is the actual power ic? - Solved
i have had this similar problem, it took alot to repair though, i replaced the battery, charging dock and i reflowed the board, this worked for me, and where is the actual power ic?
この質問は役に立ちましたか?
この質問は役に立ちましたか?
If you actually do need to replace this I.C. the cheapest place to buy a replacement from would be here.
Power Supply IC Chip For iPhone 4
Unless you are trained in replacing an I.C. I would recommend asking Hector Hector's Profile
He is a Guru at soldering.
このアンサーは役に立ちましたか?
thank you too deano, your help was much appreciated, thanks again my friend
このアンサーは役に立ちましたか?
過去 24時間: 4
過去 7 日: 4
過去 30 日: 14
今までの合計 13,029
1件のコメント
thank you alot, my friend, you are awesome, thanks to you got the repair done with and the customer was extremly pleased, thanks again
Krayzee さんによる
