メインコンテンツにスキップ
2021年に発売されたNintendo Switch OLEDモデルの解体と修理ガイドです。
Switch Still Not Turning On After Replacing Battery
I recently replaced the Battery to my OLED, and it still isn't powering on after several hours of charging on different cords and plugs. I suspect it's the charging port itself, because the joycons are also not charging, meaning the battery is still dead. Do I need to look for a repair shop, or is there a way to change the port myself? I see there are screws holding the port in place, but I doubt it just bolts in.
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
1 件の回答
Hi Andrew!
It could be a bad battery, could also be a bad USB-C port or some IC on the motherboard!
Replacing the USB-C port requires soldering. Do you have any experience with soldering? If not, then it may be for the best to let it be replaced by a repair shop!
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
Andrew Phillips さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 9
今までの合計 156
